v8sruleok
Hi all, I'm desperate for help. The car is a VR Stato V8. It has been off the road for nearly 3 years, originally it had a problem which I have not resolved but understand could be coil, hall effect sensor, or ignition module. The engine has been out of the car in that time, but is now reinstalled. I believe I have hooked up the wiring harness correctly, all connectors joined etc, and earths established as per original setup, except the coil is not yet connected, and the dizzy cap and leads are not installed.
So that is the intro.
I have connected the battery (fully charged) to the terminals.......and nothing. No power to the car at all, no circuits are live. Positive to earth across the alternator gives a strong spark. I believe that the remotes on the keys are probably dead after all this time (don't know if that's relevant).
Hope you can help, I have not messed with the fuse box(es), all relays and fuses appear intact.
Thanks, Mike.
If I resolve this, then I may have more questions regarding getting the rest sorted.
Thanks, Mike.
