wcoyote1966
- Feb 1, 2012
- 2
- 0
- 0
- Location
- Melbourne, Australia
- 1999 VT SUPERCHARGED V6 COMMODORE
Hi Guys
Unfortunately another Fog Light Question, I have a VT Series II Berlins Supercharged V6 - The previous person fitted the original GMH Fog Lights and wiring with an aftermarket relay.They were not factory fitted. The fog lights work perfectly, I was advised that the I had to add an additional wire to pin out 3 on the cluster for the fog lamp indicator to work which I have done. The problem is when i switch then on the indicator doesnt work but when I switch them off the indicator lights up. Ive tried to reverse the wires to see if that fixes the problem but it doesnt ligh up at all !!
If any ones has come accross this problem and solved it - information on a fix would be greatly appreciated !!
