i take it your car is carby? some of my info won't work,though some of it will,and may help you!
are you from armadale? do you know any of the lansley's or mcudden's?
You will need: two 30amp 4 pin relays(one will be efi relay and second will be fuel pump relay,
Take in mind these relays have number on each pin 30,85,86 and 87.
Engine loom
There will be a black plug on the engine loom with orange,violet,green and a red wire. You can snip the plug off and wire up as follows(also has red with black trace a bit further down the loom which powers the ecu wire this to ign power)
Efi relay
Pin 30 red wire from engine loom and also wire from battery to pin 30 via a 30amp fuse, so there will be two wires on the one pin
Pin 85 (negative earth)
Pin 86 (ign on power)
Pin 87 (orange wire from engine loom)
Fuel pump relay
Pin 30 (battery power)
Pin 86 (green with white trace)ALSO WITH THE VL PINK WIRE FROM FUSE BOX
Pin 87 wire from fuel pump to pin 87 along with violet wire so two wires on the one pin)
Now that you have done this there is a couple of plugs in the loom rite near the ecu.
Pink wire is anti theft this needs wiring to ing on power
Brown with white trace wire is engine check light, run your brown with white trace to a led light and then run the other pin on led light to ing power,
alternator has "l" and "s" on plug l goes to volt indicater on the dash and s is 12v power.
Use your test light and make sure your getting power at all the rite places…car should now start.
