weston
Holden VH V6 Commodore
- Apr 15, 2009
- 148
- 1
- 16
- VH Commodore
Hey guys im in the middle of building a VH commodore with a VN S1 V6 in her, I have the motor and gear box along with the full front to back wiring looms. I was originally going to run the VN cluster to have plug and play dash cluster but had trouble in fitting it up so am going with the stock VH dash cluster. My question is that Markovr has informed me with the stuff I need to mod the VN box to the VH stock speedo but I have been checking in the furum just randomly and found a post (should of saved the post lol) where a guy says I can even unscrew the face of both VN and in his case VK from the speedos and put the VN mech from it onto the VH (VK in his case).
If I was to do this would this save me having to change or get anything for the speedo to be hooked up to the box or is it just a case of having to swap the mech from the back of each speedo then just join the corresponding wires from the VN dash loom I have in car any help guys as this may save having to sorce the parts Markovr was telling me about as money at moment is a little tight or should I just go the electronic to mechanical set up cheers
Here are a few pics from what this other bloke was doing with his speedo (VS motor conversion into VK) (ha ha looked back into my comp history to find the pics etc)
