I have the same issue, I installed digital volt guage and oil pressure guage onto vz sv6 , the volt guage works fine but the oil pressure has a mind of its own ... One second I get a reading then it jumps to 120 then it goes down then back up ... Once the cars been on for a while and I stop and turn car off and start it again the red warning light will come up and a very low reading on the guage and after a while the guage will jump up again and the red warning light will turn off .... If I leave the car off so it cools down after it has been on for a while the guage will start up normal , even though its giving me a bullshit reading .... Both guages are earthed and powered from the same spot and have a inline fuse , iv checked the wire going to the sender and that seems fine too , xcept my digital guage sender came with wiring instructions and it only says to connect the one wire to one side of the sender I think it has one pin with "g" the other with "wk" ... I'm not sure witch one I used only one side is connected .... i have tested by putting another wire to the other pin on the Sender and it does nothing ...
