vxblowncalais
- Apr 28, 2010
- 17
- 0
- 0
- Location
- Newcastle NSW
- vx calais supercharged vt 11 SS.
I have installed a 5 speed manual to my vx calais with factory supercharged v6 engine. The engine/transmission loom from the manual vt commodore s pack i have is not compatable with the supercharged engine and the supercharged loom is not compatable with the manual box. The difference with the supercharged engine is it dosent have the 4 pin plug for the evr valve switch thingie. The supercharged engine has something else there that is a 2 pin plug. The water sensor is also at the rear of the engine, I am assuming i could just move the wires to this point and plug it in here. If i was to use the supercharged harness the park switch could be by-passed and the speedo cables would need to be modified if this would work. Is this even possible with all the left over cables that went to the auto? Anyone done this?:hmmm:
