Results 1 to 9 of 9
Thread: switch for WOT
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    Default switch for WOT
    Im after a switch that goes on the TPS (throttle position sensor) and switches on at wide open throttle.
    What am i looking for and where do i get one
    Check out My SV8 One Tonner
    You can get a lot farther with a kind word and a gun than a kind word alone
    VR Berlina V6
    Sep 2005
    orange
    Mount a micro switch and relay in. micro switches will be readilly avaliable at tandy or dick smiths.
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    ok, can i have more info on a micro switch and how it works
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    Check out www.jaycar.com.au and choose the categories "switches" and "microswitch"
    Those are switches with a good range of travel so with some creative gluing, or making a bracket out of metal, you could easily position it on the throttle body so it closes on WOT.
    You should also think about shielding it somehow from water and dirt or finding a water/dustproof microswitch.
    Out of curiosity, what do you plan to switch with it?
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    im trying manifold water injection for fuel economy and cleaning
    michaelw's Avatar
    michaelw is offline Donating Member
    VX S2
    May 2005
    Newcastle NSW
    If you want something a bit more reliable I'd look into either a reed switch (small currnets only) or a hall switch (needs some electronics) The advantage of this setup is that there are no exposed mechanics in the engine bay.
    Fuel economy at WOT? Be honest.
    Mike
    VT
    Apr 2005
    QLD
    Quote Originally Posted by chevy_big_block_bro
    you should be careful, have a safeguard in place for applications where you reach WOT before the engine reaches a safe RPM for the amount of water you are jetting into the intake. remember, the idea of the water is to pretty much atomise before it hits the combustion chamber. that is the way it reduces intake charge temperature........
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    Quote Originally Posted by michaelw
    Mike
    where do i get a reed switch or hail switch
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    ive put a microswitch in and only activates relay on WOT.
    being a 5 speed I only hit WOT in 2nd and 3rd as its too much for 1st gear.
    all im waiting on now is injector from hinterland
  1. air con switch? VS
    By ianf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2007, 05:23 PM
  2. Engine Cooling Fan Override Switch - Using an A/C Switch
    By Maiku in forum Holden Commodore How-To's
    Last Post: 14-03-2007, 10:59 PM
  3. ABS Switch??
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2006, 07:36 PM
  4. Removing aircon controls, mode switch, light switch
    By wrx884 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 10:53 AM
  5. What does this switch do?
    By fitykemp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-10-2005, 11:43 PM
