Vs hsv manta
- Nov 7, 2012
- 340
- 6
- 18
- Age
- 40
- Location
- Mackay
- Vs hsv manta
Ok vs commodore !!! The indicators won't work at all nothin on dash no lights no clicks neither will the hazards the fuse is no. 14 and it is fine it also does the windscreen wipers they work fine !!! The flasher relay does not get 12 volts to it I had 2 short wires and connected from relay to its holders the earth and the indicator wires and ran a direct 12 volt supply to the relay and that works so its the power supply to the flasher relay !!! But where does this come from its a blue wire with white strip and goes onto a bundle of wires and dissapears ???
