Bigjase78
Hi I'm hoping someone can point me in the right direction with this electrical issue I'm having with my vb sle. About 7yrs ago I done the injected 5ltr 5spd conversion myself accept for the wiring.I have always keept it well maintained I give it regular services oil plugs leads filters dizzy cap rotor button and its never missed a beat couldn't be happier with the old girl that was until a couple of weeks ago, It would backfire throu throttle body n splutter then take off then started running ruff when cruising round town usually between 60 & 80ks didn't have its usual nice quick smooth pick up but if I dropped it back to second & booted it away she goes no problem clean crisp like there was nothing wrong. Slowly it got worse but why? What could be causing this? I checked plugs leads dizzy cap rotor button coil swapped ignition modules stil same problem? Then just as got home left it running while opened gate & shed jumped back in to put it in shed & cough splutter pop bang throu throttle body chugg chugg roar back to life pull up in shed & it died.... Fuel pump starts throwing tantrum cutting on and off thermo fan starts doing the same I turn ignition off & wtf thermo fan clicks on & off the light in elec aerial switch comes on with thermo goes off with thermo??? Hmmm ok try start it again turn ignition on fuel pump splutters on & off cranks ova starts for 1second and stalls? Turn off ignition thermo turns on & off light in elec aerial goes on & off with thermo. Try again this time no fuel pump at all replaced relay still no fuel pump? Checked oil pressure switch all good ok removed fuel pump relay connected external power supply to fuel pump & works perfect crank it over same thing starts for 1sec & stalls? Try again but held key in crank position just backed off key till starter disengages & engine keeps running bit erratically idoling up & down let key go & it stalls? Also if I leave efi & fuel pump relays in they get hot even when ignition is off. I checked all earths, alt connections fuses and all were ok. Please can someone make sence of this & point me in the rite direction! Any help will be much appreciated.
