decrepit
It's a factory fitted gas conversion, late 2006.
while on petrol with gas conversion hooked up, my 06 vz wagon, has a very small signal to #3 petrol injector, which fails to fire.
If the gas conversion wiring to the petrol injectors is disconnected and the original plug connected straight into the manifold socket, it works fine.
I suspected the gas computer, but just to be sure I've checked continuity in the gas conversion wiring from petrol injectors back to gas computer, with some strange results.
I was expecting 6 direct connections between both plug and socket to the plugs into the gas computer. Checked the plug first and only found 5 direct connections, I then checked the socket still expecting 6, the extra one revealing the faulty connection on the plug. BUT!!! I could only find 4 direct connections.
So has anybody got a wiring diagram of the gas conversion?
I'm especially looking for the pin numbering of plugs and sockets between gas converter and the petrol injectors.
Anu theories as to what's actually happening would also be appreciated.
