vs-lover
- Mar 9, 2013
- 2,644
- 1,812
- 113
- Location
- Adelaide
- VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
Hi all,
I have a 97 Statesman and had to remove the instrument cluster to change some light globes that were intermitently working. I have put everything back together but now I find that the airbag light comes on when you switch the ignition to on as it should, then it goes off and reilluminates and stays on permanently. I've pulled the fuse out and waited then reinserted it and it still stays on.
I'm lead to believe that if the ignition is turned on while the cluster is removed then this will cause this.
Any help would be greatly appreciated.
Cheers to all.
Cheers to all.
