VY Air Con Won't Blow Air
Holden1856
Cranbourne
VY Calais
My 02 VY Calais won't blow any air out any vents, it doesn't matter what fan setting i have it on nothing comes out.
Any help on this would be greatly appreciated!
Thanks
Kieran.
redhot.
NA, Open Diff, Auto
Coffs Harbour, NSW
VY Executive S2
Check your fan speed resistor, it is located behind the glovebox
This is it here, unplug it and undo the two screws.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Holden1856
Cranbourne
VY Calais
Here is a photo of my resistor redhot. it looks ok to me but i don't really know what I'm looking at
When you say it wont blow air out of any of the vents. Do you mean the fan is working and the vents seem blocked,
or the fan isn't working at all.
I can't hear the fan working at all Nut Kracker
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Well....it's unlikely it'll be the resistors as the 4th speed by passes them and runs through the blower relay.
If the relay and fuse are good, it may be the fan motor it's self.
Try wiring up the motor directly to the battery, by passing the car's wiring and see if it works.
Other than that, see my "How To" in post #3 of this thread.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
By the way. The resistors will get hot but if the fan motor is cactus it can damage the resistors if the fan switch is left on at the lower speed settings for too long.
Holden1856
Cranbourne
VY Calais
So i put 12v to the blower motor and got nothing. So i pulled the motor out, pulled it apart and it was full of dust dirt ect, cleaned it all & now she works again
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Well done....glad to here all is good.
