allthis4what
hi everyone.. ive been having some issues since i hit a pothole a few weeks ago. I dont even know where to start.. my alternator light has been on since this happened but everytime i checked my battery it was still fine,when i turn the lights on the battery light dims, the demister light has come on and will not turn off, and if i turn the demister button on sometimes the demister light and the engine light will go out.. ive replaced the alternator twice, ive changed the battery, ive replaced the fuseable link, ive checked the plug to the alternator, and last night we checked the error codes and they flashed through the demister light and had no engine light, came up with an error 55..
The tester says the alternator is fine and and now the computer says it has no errors but i havent driven the car since because it will start a few times then i will have no power again. No dash lights or anything.. the fan plug has melted a bit and it turns on within 30 seconds of starting the car and never turns off... if i turned the lights on when we checked the error codes, the codes flashed through the park brake light and everything... the dash lights arent doing the exact same thing every time either.. but the demister light will be on constantly ....i would like some thoughts on what else i may need to replace or check.. hopefully it wont be an auto electrician... thank you to anyone who may be able to make sense of this insaneness..
