pedroc
Guys I'm after advise on charging a flat battery without disconnecting it from the vehicle. Car is a 03 VY. Have looked through the forums but seem to find conflicting info. Got an Arlec 2500 compact charger, instructions on the charger state " Ideally, disconnect the battery and remove from vehicle. If this is not practical, ensure that the battery terminal not connected to the chassis is connected first to the charger. The other connection is then made to the chassis, keeping away from the battery and fuel line. Only after connecting switch on the main supply to the charger".
Basically I want to know if using this method I am risking damaging the electronic system in the vehicle?
I don't want to take the battery out to charge as I don't have the radio code and don't really want to fork out $$ to get it.
Any advice appreciated.
