MYVESSV8
- Nov 28, 2009
- 3,074
- 330
- 83
- Location
- Brisbane/GoldCoast
- VE 6LT M6
ok have added auto release using button inside glovebox to open hardlid (have single lock version) used solenoid from vz sedan, boot button, found pinout for button release activation, hooked all up and works perfectly (used relay to operate solenoid wasn't sure of bcm relay current rating) so bcm output sidnal to relay and all good.
what I want to do now is have it remote opening from key fob (so open lid or doors) the remote for utes is 2 button so no boot feature, is it possible to have a 3 button sedan style key programmed/reprogrammed to suit the vz ute so the boot function is utilised for opening the hard lid.
new lids now have this feature, can it be retrofitted to a older model, when you push the boot/hardlid open button in glovebox a warning symbol (looks like a lock/padlock open)flash's on the dash:help:
