vy commodore battery test fine still wont start occasionally
hk383
caboolture
04 vy commodore
hi guys. I just bought a vy . it has stopped on me 4 times now over a span of 6 wks given or take. I had the battery tested...volts - 12.69 measured 202 cca rating 470 cca start test low capacity 8.74v charging test 14.12 v. I took the battery out and charged it over night, all was good till it didn't start today. would I need to change the whole alternator or just do the brushes or regulator or both....or would it be something else ? ooh my abs light on the console beeped at me 2ce in the past 6 ish wks aswell....
Tasmaniak
Not a valid input....
41
S.E. Melbourne
www.ranjinstallations.com.au
Is it cranking? If it isnt cranking, turn the headlights on and then try to start, hoe much do they dim?, if they dont dim... batyery and alternator are fine.
hk383
caboolture
04 vy commodore
it cranks yes.I had the battery checked they said it was fine, I just want2 know how & what the problem is. starter motor on its way out ???
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Check all your earth leads and terminals both to the block and the chassis where applicable.
hk383
caboolture
04 vy commodore
ok..I dont know were they are. im just a girl with limited knoledge :) ive taken the alternator out & pulled the regulator off...there is burn marks on it & on the spring things on the alternator itself.
hk383
caboolture
04 vy commodore
I put the new regulator on. do I need to charge these battery overnight or can I jump start it ?
redhot.
NA, Open Diff, Auto
Coffs Harbour, NSW
VY Executive S2
202 cca? That is ####in nothing, like you said it's a 470 cca battery, it should put out at least 450 cca.
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
battery should be 75% of cca to make it anywhere near reliable to start, as the weather gets colder the battery will not be good enough (it is slowly getting cooler here in Brisbane) so watch out, not necessarily brush sets (alt or starter) could be slip rings, pinion gear, solenoid, just a few things to keep in mind, you can jump start (but do it the correct way) burn marks on the brush gear/regulator of the alternator can be because it is trying really hard to charge battery after starting (battery not in good state)
mesa93
30
caloundra
VY
did anyone find the cause of this, my vy is doing similar
bj51
darley victoria
VT calais v6 series I
i had the same problem with my vt it was the earth lead on the block left loose by a (cough) mechanic (cough) I was able to get a full turn on the bolt and have no probs since
