1991VNvacationer
- Jun 9, 2012
- 88
- 0
- 0
- Location
- Melbourne
- 1991 VN Vacationer 1971 HQ Kingswood
My kingswoods has a 186 engine from a HT. It was running fine and then it started to run rough and then completely quit. i tried to restart it but know it only runs for around 3-5 seconds and then turns off, you can keep it running if you violently pump the throttle and keep the revs up, but it will not idle. The next morning i tried to start it but same thing. But the coil got extremely hot, too hot to touch. I have an external ballast resister and now, that's not getting hot nor warm. i cannot figure out the problem. I've tried replacing the coil but same problem. The points look health, and are fairly new, but i did not use a dwell meter when installing them. should i change to a electronic distributor. Also i found two wire melted on the exhaust, i think that it may have something to do with it.
