Vy fog light switch
jonny6guns
VS MALLOO UTE,HSV ENHANCED 5 LITRE
I have vy commodore ,It has fog lights fitted but they weren't plugged in when I bought it.i have plugged them into the existing plugs but discovered the switch has no pull out knob or icon of fog light on switch.im guessing they have just put the fog lights in to fill holes.....my question is if I replace switch to a fog light capable one will it work or do I need to do any rewiring
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
So you have found the wiring behind the lights and plugged them in....yes? That means the loom should be there for them.
And what I gather, the switch is a dummy...yes?
If so pull out the dummy switch and see if there is a plug there. If so, get a switch and you should be set to go.
hakhawk
smooth moderator
Staff member
its a vy, so the foglight switch is actually part of the headlight switch.
if the wirings there, one would assume it needs a foglight equipped headlight switch, possibly a fuse and the relay installed in the fusebox
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Oh yeah....VY...D'OH.
Anyway, as hakhawk said ^^.
