bluekart77
OK so i found the "brown wire" in the VR, but the signal wire in my 2000VT V6 5spd IS NOT TAPED TO THE LOOM IN FRONT OF THE FIREWALL NOR IS IT ALONG THE PASSENGER SIDE STRUT TOWER!
the loom in front of your coil pack with the right angled plastic cover over it, is where it hides!!!
there are 3 brown wires, but two go into the DFI module plug, splice back both, cause one works and ones a bit of a dud, i had no fancy test light, i just touched the tacho signal wire to either and went with the best read, IT WORKS!!!
SO for those that cant find it, this is where it hides.
cheers, im going racin!!!
