When you say they range from 9-36V, do you mean that is their voltage range? i.e. can be used from 9-36 volts?
Or do you have different leds with different voltages?
Parallel doesn't draw anymore power.
If you have more than 1 light, say at 12 volts for a 12 volt system, they have to be wired in parallel as pictured above, so as to get 12 volts to all lights.
If they are wired in series, you would need 36 volts to power all 3. (3x12v=36v)
You can think of series wiring as multiple lights made up to make one light at the required voltage (eg 12v).
In the pic below you can see one wire jumping from one light to the other...N to the negative side of the battery and P to the positive side.
So really, those three individual lights become one.
If you have 2v lights, you would need 6 lights to make up 12v. 4v lights you would need 3 and so on. (6x2v=12 and 3x4v=12)
The only problem with series wiring is, that if one of the lights goes out, the whole lot will go out because the circuit has been broken.
Just like those damn Christmas lights.
This site will explain it better for you.
Series and parallel circuits - Wikipedia, the free encyclopedia
Series wiring example.
