jasonshortis
- Jul 29, 2013
- 2
- 0
- 1
- Location
- west melton
- wh statesman 5.7
hi all,I have a problem with indicators and curb turning lights.A while ago I replaced my indicator stalk because it didn,t cancel turning left.Not long after that I noticed that the curb turning lights were not working anymore,I didn,t worry about it too much at the time but a while later when I indicated left or right it would flash the high beams as it cancelled.Thinking I had a faulty indicator stork,I replaced it again.This time every time the indicators cancelled the high beams stayed on,I exchanged switches at holden but the problem remained until I put pressure on the switch body where it slides into the column mount using 2 cable tie ends.This stopped the high beam issue but the curb lights still don,t work.If I earth each curb light they light up.I pulled the indicator switch out again and noticed that where the curved plug goes onto the switch I have an extra 3 female terminals with wires in my wiring loom but the switch has no male terminals that go into them,the switch has 3 slots in the plastic body that would line up if they had terminals though.I have tried to find out from holden if statesman switches are different to commodores with cruise but they can,t tell me because the series 1 switch has been deleted,bursons doesn,t have a different listing although the bloke that served me recalls hearing that they might be different.Can anyone help me with this?Do I have the wrong indicator stork or do I have a body control module issue?Thanks every one,Jason
