vlturbsk1
i just recently bought a rb30 motor for my vl and when i purchased it from the previous owner it ran perfectaly.
now what the problem is i cant get fuel to squirt out of the injectors the only time i got them to squirt is when i ran power straight from the batery to the injectors, just to see if they were working ok and they did.
everything electrical that i tested is ok such as the injector leads, they have a pulse when tested with a test light but only problem is they had no ground which im guessing is the problem but how can that be fixed? new loom?
also my efi really and all other fuses are ok
extra info-
full tank of petrol and yes it does prime
has spark
timing is correct
extra info-
has spark
timing is correct
