Vr statesman high beam problems
Vr statto
Wodonga
5ltr statto
Hi all
I've got a problem with the high beam on my vr statto.
I've got high beam at the h4 globes but not at the h3. I've checked the earths
Changed the globes checked the plugs changed the stalk changed the relays and still nothing
Has anyone else had this problem. Or can any one give me any hints on what else to check.
Cheers.
Tasmaniak
Not a valid input....
41
S.E. Melbourne
www.ranjinstallations.com.au
Whats missing at the plug... Power or Ground?
Vr statto
Wodonga
5ltr statto
I think it's not getting power I pulled the high beam relay out and turned it
Over and the 2 green wires for the high beam have power when the lights are on low beam
But when you switch to high beam there's no power.
Tasmaniak
41
S.E. Melbourne
Does the H3 come on when you flash your headlights?
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Checked the high beam fuses??
Vr statto
Wodonga
5ltr statto
Nah I've got nothing what so ever at the h3 and yeah I've checked all the fuses
Tasmaniak
41
S.E. Melbourne
so... no ground and no positive? You have a plug disconnected somewhere. Most likely cause to have lost both.
Vr statto
Wodonga
5ltr statto
I found the problem I followed the 3 white wires up the loom from the head light plug and there was about a 2 inch section where the wires just corroded away no wire what so ever left in all 3 just powder lol but fixed now thanks for your help
