dasweetdude
- Jul 26, 2013
- 9
- 0
- 0
- Age
- 46
- Location
- Frankston
- VT 1999 Berlina S2 Supercharged V6
I had some work done to my car and after l got it back l wanted to change the battery from my VR to my VT when l did this it was raining and well cutting a long story short the battery was put in backwards by my friend and reversed the polarity and the alternator caught on fire. So yeah it was a big spark l took it for a drive shortly after and everything works fine except the Heater and the Radio sometimes the heater works and the fan works and sometimes the blower drops out and doesn't work the demisters works fine just the blower doesn't blow air. The radio doesn't work at all never turns on so l don't know really where to start to try and fix the problem. I checked the fuses and relays and pretty sure its not them unless a relay works and then drops out. I could use some advise l know it could be the computer but l doubt that this is the problem l got a new alternator and all is good minus these 2 problems. Any advise would be great.
