DanVS
Ive got a VX R8 Clubsport manual that was puchased as a wreck for a conversion, id like to get it running to make sure the engine and box are ok before i proceed.
It doesnt have a key so i sent the ecu away to have VATS removed, the ignition barrel and switch was busted (probably been stolen) so i fitted a secondhand ign switch and it still wont go, is getting fuel, can hear injectors working but no spark.
It will turn over on the starter 3 times then stop, also i noticed a little "x" on the left hand lcd display on the dash??
Id really appreciate any info to get this thing running, thanks in advance
