St8iZ
Yes MMAAAATTTEEEEEE!!!
- Nov 18, 2012
- 7
- 0
- 0
- Location
- Ringwood
- WH Statesman
Just recently purchased a VYII Ute and i'm having an Immobilizer problem ... the issue is it will crank but not start ... sometimes it wont crank at all ... the immobilizer light still flashes locked but it will start after a few or a lot of tries ... It passed a roadworthy and my mechanic ran a tech2 over it and came back with Immobilizer ring fault ... he cleared all faults from the computer record which worked a treat but only for that day ... since then i have replaced the ring but same issue keeps coming up ...
On the other side the key is what looks like a none genuine case as in no holden logo and cheap ebay buttons and the buttons dont work at all so i have to manually unlock and lock my car with the key in the door ... my question is this
Does the central locking button when pressed to unlock disable the immobilizer before entry and is it possible i just need a new key to fix this problem?
After comparing keys with my Statesman key it seems that my statesman keys immobilizer part on the key protrudes an extra couple of mm's so that might also be an issue but just seeing if anyone out there has been through this forum and tried all the advice but still not finding the solution ... Ive been through all the treads here in relation to this yet nothing has fixed it without going for a new bcm etc. any help will be great
