nexx
Hey all, looking for some advice on a VZ SV6 as I'm unfamiliar with commodores and I hear a lot about BCM issues etc.
The situation is, after degreasing the engine bay fusebox (filled with red dust) and cleaning relay terminals I have absolutely no power to the car at all, no central locking, no lights, no ignition surround light, no dash cluster. Dead in the water. I've run through all the basics that I could think of, so I'm looking for some advice before I hand it over to an Auto Electrician. Is there something obvious that I'm missing? Here's what I've checked so far:
Continuity
Intake manifold/block -> chassis
battery (-ve) -> chassis
Intake manifold/block -> battery (-ve)
Intake manifold/block -> battery (+ve) -> short!?
Relays
Ignition (under dash) -> audible click from coil
Engine Control Relay -> audible click from coil
Swapped a few relays around to try and eliminate them.
All fuses have continuity (not blown)
Fusible links look okay
All relay pins in the fusebox have continuity to battery(+ve), (-ve) seemed hit and miss -> Bad ground/short from degreaser?
Alternator charge wire has continuity to battery (-ve), possibly through short elsewhere as removing charge wire had no effect on problem and block still had continuity to battery (+ve)
Cheers for any help.
Continuity
Relays
