PIR4TE
Banned
- Mar 15, 2011
- 2,747
- 74
- 0
- Location
- AWOL with Ari
- Black Pearl
I am looking to reduce heatsoak, gain some thermal efficiency and reduce parasitic loss from the front dress in my 2011 L77 by swapping the mechanical water pump with a Meziere WP329n electric unit.
I welcome feedback from anyone who has fitted a Meziere, particularly one managed by a digital PWM controller such as the Davies Craig unit.
I have an SLP 160°F thermostat and intend setting the operating temp via controller to 80°C (176°F), and will occasionally set it to 75°C (167°F).
Would the ECU (BCM?) have a spit if I were to simply disconnect the appropriate one of the two thermatic fans from the harness and have that managed by the Davies Craig controller?
Also I run almost exclusively on e85 with original plugs at the moment, any advice regarding revised heat spec / plug gap would also be appreciated.
Documentation
Documentation
