jgtoranalc
- Jan 23, 2013
- 607
- 3
- 18
- Location
- Adelaide, SA
- Holden Statesman VR HSV 5L, Holden Torana LC
I've just relocated my battery to the boot of my Holden Torana LC.
Now I have a Battery that is sealed with battery box fitted. I also have the vent tubes.
Now the battery has 2 vent ports and both are opposite sides of the battery.
My question is... Do I have to place hoses in both vent ports or can I just block one so it only goes out one side only?
or is it the way it works as one vent is for 1 set of cells to vent while the 2nd vent does the other set of cells?
The left hole is a Vent Port. and on the other side of the battery is the other one.
(The Right hole is nothing -basically used for the handle hinge)
It's the only thing left to do then I can finally fit Triple SU's in as battery was in the way
