peaceboy666
- Jan 24, 2014
- 5
- 0
- 0
- Location
- adelaide
- vs swagon series 2
had car broken into not long ago and i knew the indicator arm was a bit dodgy after they had smashed all my ignition, and not working well but persevered for a few weeks.all off a sudden the other week my headlights and tail lights stopped working, as well as the fixed forward high beam position on ind. arm,then indicators stopped working too.funny thing was i had headlight switch on and then wiggled the dodgy indicator arm/switch ,headlights and tail lights would kick back in, turn headlight switch off n on,no lights again till ii wiggled the indicator arm around. i assumed it was just the dodgy indicator arm which i replaced n indicators now working but cant get no headlight or tail lights even with a slight wiggle of indicator arm, also no high beam in the fixed forward position of indicator arm.any help would be greatly appreciated,would it possible be a relay under the bonnet or the actual headlight switch maybe? bye the way all my fuses were fine bar number 4 which was sum general illum thing(no idea what that does), i dont really want to pay an auto electrician if its possibly a simple fix.
