VY Dash and LS1 custom install, wiring advice needed
genclubby
hi all,
I hope i have posted this in the right section.
I have fitted a VY firewall along with the complete dash including the heater box and LS1 engine to 1985 trans am.
I am using the VY chassis wiring loom along with the fuse box, relay box, PIM, BCM and ECU.
not using traction control.
I am currently hunting down a Ls1 wiring loom.
Hoping someone can help me with a few questions:
1. are the LS1 wiring looms all the same from VT11 to VY?
2. is the throttle control controller needed for cable accelerator?
3. is there anything else i should be considering?
Thanks
Vin
JTR007
30
VB, VN, VS, VX & VF
Looks good mate!
Hopefully someone will be able to help
Sent from my GT-I9305T using Tapatalk
Zlimes
My Vt accliam lovely leds
30
Newcastle nsw
Holden vy commodore
Hey mate I would get a the full vy wiring out of a ls1 and install it
As u will need
Fuel pump v8
And a v8 bcm ecu key head all linking
And make sure it's out of a vy ss or u run into trouble with climate control
U will need to get ur air con re-gass to
Zlimes
30
Newcastle nsw
Holden vy commodore
And is the heater box out of a vy ss or a normal vy with out cilmate control
