Farlap
Hey,,,
Trying to install a shift light into a VZ, had a search and looks like the 'only' way to do it is run a wire through the fire wall into the coil packs for tacho reading..? Why couldn't I use the tacho wire in the dash cluster wiring instead? (by the diagram I have here is the brown/orange wire) which is alot easier so I can steal power and ground at the same time...or is this a multi purpose wire and will not work?
