VE S1 Rear power window fault
jackstafa23
Toowoomba
2010 VE Sv6
Hey Guys,
Im not sure if anyone else has had this problem but my Rear Driver Door power window wiring system has *Derailed* as such and I was wondering if anyone had the wiring diagram or new the easiest way to fix it,
Any help would be appreciated.
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
What you mean by derailed? Could you be a little more specific?
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Hmmmm.....Derailed you say?
jackstafa23
Toowoomba
2010 VE Sv6
I do apologize for my lack of details,
***I AM PROBABLY THE MOST CAR ILLETRATE PERSON ON THIS SITE***
Anyway,
Within the door, as I describe it, the steel wire has come off its runners or guides if that's makes a little more sense.
I do apologise for any confusion
Tasmaniak
Not a valid input....
41
S.E. Melbourne
www.ranjinstallations.com.au
wiring diagram can't help with that one mate. You will need someone to hold the glass up to take tension off of it and the slip the steel wire rope back over it's pulley.
Take a picture to show us whatshappened if you can.
