VY SS Cruise Control and Traction control not working
Jaiman
NE Melbourne
Stroked 4L VP
Hey guys.
Have tried doing a search for this and found different issues but mine seems to be different again
When I normally started the car, traction was on and everything worked ok.
Now sometimes when i start the car, traction control is already off, i cant turn it on and cant turn cruise control on
Other times when I start the car, traction is ON, I can turn it off, can turn on cruise control but can't set it at any speed.
I had the car looked at and scanned and was told brake switch was faulty, got one fitted and still nothing.
only other thing that searching has come up with is ABS module... are they expensive to replace?
Tasmaniak
Not a valid input....
41
S.E. Melbourne
www.ranjinstallations.com.au
Yeah they are expensive to replace, but often times, it's not that. It something as simple as one of the ABS sensors at the wheels. Sometimes, the sensor is faulty and sometimes the plug is just dirty! What you really need to do is have the codes pulled from the computer. It'll give a good indication if it's a wheel or the main ABS module.
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Did you replace the right brake switch? There are two, one for the brake lights and one for the cruise control.
BRAKE
CRUISE CONTROL
Images courtesy of st3r3otyp3
Jaiman
NE Melbourne
Stroked 4L VP
BRAKE
CRUISE CONTROL
I only replaced one...
But the one I replaced was the bottom one (cruise) which is up higher than the brake one.
No Change
Jaiman
NE Melbourne
Stroked 4L VP
I did only change one...
but it was the bottom one (cruise) photo that you show there. (bitch to get to being above the other switch)
No change
Muke
VE SV6 MY08
I'm with Tas on this one, you need the actual code being thrown. On the VE at least, there's something like 4 codes for what is wrong with the brake switch. Could say low or high voltage, faulty signal, difference between the two etc. And a "faulty switch", doesn't mean the switch is the cause. Very easily could be the wiring or plugs. To use the ABS sensor example again, it seems to be the wiring more often in the VE according to the number of posts. Generally a good idea to try and confirm the fault before replacing things if you can to save wasting money. The codes are an indicator to the problem, not a definite answer. Good luck.
Oh and if you've had a garage read the code for you, see if they'll redo it for free. Seen a few places do it, as that's their fault finding procedure. Read code, clear code, tell you to come back if the fault returns to read the code again. Lazy way if you ask me, last time I had this was for ABS sensor fault. Pricks didn't even swap the sensors over to see if it swapped sides, or as I did when I got home and spent 5 minutes with a multimeter to confirm the fault (2min if the car was on a hoist). Easy way to make $100. Especially as the code never went away (well was there as soon as I turned the key to ON).
Jaiman
NE Melbourne
Stroked 4L VP
thanks for that.
So basically my best options are:
- Go back to the mechanic, get them to see if codes still come up.
- Test my ABS Sensors at the wheels.
I'm slightly confused by what you mean by "code being thrown" or "codes pulled from computer"
(excuse my ignorance)
Muke
VE SV6 MY08
All good Jaiman, everyone is ignorant until they ask the question. Especially when we tend to talk in terms you're not used to. Still a hell of a lot I'm ignorant about. So I'll try to explain better.
By "code" we mean error code (or DTC - Diagnostic Trouble Code). By "computer" we're referring to the ECUs (Electronic Control Unit)s. So that covers all the modules, or control boxes. Such as the ECM - Engine Control Module, BCM - Body Control Module, ABS Module etc. So every time one of these control modules notices something wrong with it's system, it will log an error code into memory. Meaning any problem encountered or odd behaviour should have a code stored in memory to tell you what part of the car the error was in. They can be current codes or historic codes (well the VE certainly keeps historic codes). For example, whenever the Check Engine Light comes on, a code is stored showing what caused that light. If the problem is still there (light still on) it will show as a current code, but if you fix the problem (light goes out) the code will show as having been an issue, but is not currently a problem. "Clearing a code" refers to wiping it from memory with a scan tool. When we say "thrown a code", we are referring to the error code logged by the control module that is relevant to the problem. By "pulling codes from the computer" we are talking about reading what the error code is. This is mainly done by using a scan tool on modern cars. Which is "having the car scanned". This covers things like a Tech2 (used by holden) or the cheap OBD2 dongles that can do limited things on cars after 2004 (or 2007 - I always forget) when all car makers agreed to standardised systems so mechanics don't have to buy a new scan tool for every make of car. Older cars, like the VN/VP can have the error codes read by shorting out 2 pins on the diagnostic connector and the check engine light flashes a certain number of times to give the code. But they are a lot less comprehensive. (The VN has 18 possible codes, the VE has hundreds, I guess the VY is somewhere inbetween)
When you say you had your car checked out and scanned, I assume you mean the mechanic connected his scan tool to your car and ran a diagnostic check. It would have shown a code that he (or she) looked up and told them what area the problem was in. Now I went from a very basic VN to a VE, so I don't know much about the codes the VY uses. There are general codes on modern cars with OBD2 (On Board Diagnostic 2) as well as more specific ones for different brands/models. But on the VE at least, I'm pretty sure it wouldn't say "brake switch faulty", but which switch and what the problem is. Such as "switch one signal too low" or voltage to high etc etc. I can only guess that the VY having two switches would give at least a code of which switch and hopefully what also. But I'm not sure. I found a list of 45 error codes, but none mention brakes. :( Though the throttle position sensor does also list what is wrong.
So hopefully your mechanic is pretty decent and will help. I'd give them a call and explain that you saw them and was told the brake switch was faulty, but replacing it didn't work and was wondering exactly what code came up and if there was any more info they have for you. With some luck they will get you to come back in to re-scan it for free, or can at least tell you some more info (assuming they took a note of what the code was - check your receipt, they might have written it down on that). If the other brake switch is cheap enough, it might be worth just changing that. Especially since the mechanic did say it was a faulty switch - well if he didn't specify which switch.
As for the ABS sensors, well that's really a bit of a guess on our part. Mainly because that is probably the most common cause of this type of problem. Without knowing exactly what error code was found, we can only guess. On the VE it has a different code for each wheel, so an easy test is to check the code and then clear it and swap two sensors over. If the code changes it is the sensor, if it stays the same it is most likely the wiring. But the VY might not tell you which sensor it is. Again with the caveat that I don't know VYs, you might be able to test the sensors with a multimeter (this worked on my VEs sensors). Simply by testing the resistance across the senors pins, I could see one was stuffed. On the good sensor, I would get a resistance reading in one direction only (swapped the test leads to the opposite pins). On the bad sensor I had a resistance reading no matter which pin had positive or negative test lead on it. Pretty sure that's correct, either way it was very obvious they were testing differently. And see if you can trace the wires back and check any plugs. As Tas said, it can be as simple as a dirty plug (or loose/damaged).
Geez, I hope that makes some kind of sense. I also just noticed you said the traction was off, but didn't mention the ABS being off. Usually they're highly linked and both would be off (they use the same wheel sensors). Surely if the problem is either the brake switch or the sensors the ABS is off and warning you. Anyway, good luck, and hopefully someone with some more knowledge (especially with regard to VYs) can clarify or fix anything I've said that may need it.
neephius
VY 5.7 M A4
some times if you replace rear globes in your brakes with LED tale/brake lights this will upset the voltages and traction control and turn it of completely. Just a thought.
Jaiman
NE Melbourne
Stroked 4L VP
thanks for all the info Muke. appreciate it
I walked over to my mech just then and had a quick chat.
I think we are just going to start with replacing both brake switches again just to make sure,
Thanks Neephius but I havn't changed the globes at all and they are normal ones.
Although One thing I didnt think of earlier is that some time ago (even a bit before this happened) I know that from time to time, 1 brake light would be significantly more dull than the other side or sometimes not work at all. I could wiggle the wiring and it be fine, then a few days later the previously good side would go dull or not work.
So I think It's going to be:
Replace switches again:
New Globes and play around with wiring in the rear of the car and see if there is a short or something that plays with the trac/cruise
