Results 1 to 4 of 4
Thread: Common Vl Fault
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    one thing holden might have made a boo boo on is the vl aircon circuit.
    after a period of time, and due to the car's age, the fuse holder for the aircon tends to melt, making all sort's of problems arise due to this
    the cause of this is because the cable holden put in for the fuse is the right size, the fuse is to big, and as a result of that, the plastic will actualy melt away before the fuse will blow. this does cause quite a few problems in the vl. the best way to repair this problem is a cheap and easy way
    simply cut the cable that is on the aircon only, no more, at the fuse box that is.
    then go out, and buy a fusable link, it's a realy cool looking thingy, it's got 2 cables and a little fuse holder, simply join the cables together, it dont matter which cable goes where on the fuseable link, it can only go in 2 way's of course, but make sure there is only 1 cable at each joint. when you join them, twist them together, with a pair of plier's or by hand, eitherway, make sure no strands are sticking out. using a gas torch, or a hand held soldering iron, head up the cable, use some solder to join the cables, this offers' less of a chance of repair comming undone, and makes a better connection, and elimenates anychange of a electrical hotspot. alow the cable to cool down, and wrap with insulating tape, this will help insulation from other cables,
    it's as simple as that
    cheers
    garth
    i am the god of britany spears womanizer on just dance on the wii
    MaNiac_VP is offline Mr Moderator !
    VPII Calais
    Oct 2003
    I had this problem on my gfs VL exec, but i didnt realise it was the fuse causing the problem, and after a few months it burnt out another fuse and after opening and finally looking in her fuse panel box i realised why it wasn't working.
    Hell yeh to that fusable link! I use them a few times in my stereo set up as well i think my car would have prolly burnt to the ground by now if it wasn't for them.
    VPII Calais
    Oct 2003
    mickey Guest
    mmmm 38 degree day chiselling burnt plastic from the fuse box while GF cooks in the cabin... ahhhh those were the days... (when the air con worked!!&#33 Thank god for my VP!
  1. Common threads. . . . .
    By deserthead in forum Site Feedback / Site Problems
    Last Post: 21-05-2006, 07:26 PM
  2. Common (unknown) Seat Fault with VY - check yours
    By VY Equipe in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-04-2006, 09:13 PM
  3. Whats the most common used CAI?
    By cb1177 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-01-2006, 08:15 PM
  4. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
  5. Valley Gaskets - common fault ???
    By dontsailbackwards in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2005, 01:21 PM
