Terrystatesman
- Dec 29, 2012
- 16
- 0
- 0
- Location
- Oman
- 2004 Chevrolet Caprice (WK Statesman)
Hi guys.
Hope someone can shed a light on this problem.
My car is actually a 2004 Chevrolet Caprice LTZ, 5.7Ltr V8
When the weather is really hot, when I unlock the car with the remote, the interior lights stay on all the time. If I lock the doors after getting in the car, the interior lights go off after around 20 seconds, as long as I do not put the key in the ignition switch! After the lights go off though, when I put the key in the ignition switch, they come back on again! If I put the key in the ignition switch straight away, the lights stay on permanently whilst driving, when they are meant to go out as soon as the key is inserted.
I suspect that it is something to do with one of the relays in the BCM (Body Control Module) sticking when hot? But which one?
The only info I have found is the "common" problem of the indicator lights staying on after locking the car, and that can be fixed by replacing the one relay in the BCM. But my indicators flash as normal. It is only the interior lights (all of them) that stay on.
Does anyone know which relay is the dome light delay timer relay in the BCM. I suspect that it is the one beside the indicator relay (the bigger one)?
I am not in a position to have this diagnosed, as nobody here in Oman has a tech2! Of course, that also means that I cannot replace the BCM, as there is no way to programme the replacement BCM. I can get 2nd hand BCM,s, but they are a bit expensive, but if I could find one that has the same relays inside, I would buy one, just for the relay, and replace that relay, (unless someone knows where I can get that suspect relay?). But, given the price of a 2nd hand BCM, not knowing if that relay is what is causing the problem, is a bit of a monetary risk, so I have come on here to see if anyone has any knowledge of this problem?
The wiring diagrams I have found are for the WH Statesman/Caprice, but the colour coding for the wires to the BCM do not match the actual car, so diagnosis would be almost impossible! I had wanted to cut either the dome light on signal wire, or the door jam input wire, in the hope that without that signal, the BCM will not have control of the interior lights! What I mean is to try and isolate the BCM from controlling the interior lights?
As things stand, I have removed the interior lights fuse.
Here is a photo of the BCM that I pulled of the internet. I think the interior lights delay timer is the bigger one JQC-16FV?
View attachment BCM.pdf
Any help or suggestions would be most appreciated.
Terry
Terry
