I have Statesman WH II (actually left hand drive i.e. Caprice 2002). I don't know what happened but when I turn on my car both fans start to run at full speed even if engine is fully cold and even if I switch off my car then fans run forever which kill the battery. If I move the key in ignition mode in order to start the engine but without starting the car and I remove the key then the fans stop immediately..
What could be the reason ? Has anyone experienced such issue ?
Yesterday the mechanic removed the radiator to replace the crankshaft pulley which was terribly overheating the car which kept sometimes the fans running for few minutes after car being turned off but then used to stop by themselves but now they keep running for infinity ..
