My young bloke has a 2004 VY ute,
The other day he mounts the curb at speed and writes off 3 rims and tires, no biggie there only out of pocket $1600 and a good lesson learn't.
But he tells me that the " check alternator" came on, since then the indicators wont work and if you try them the relays under the dash just buzz and the electrics go crazy.
I checked the fuse and relay mounts under the bonnet, the mounting block is broken in two, I don't know if this was like it before or after the bingle.
I am trying to work out, if its the relay block under the bonnet or could it be the Body Control Unit, and where could I find the BCU to check.
The electrics were fine before the prank but since then, chaos.
Any help would be hugely appreciated#
Cheers#
Faz
Cheers#
Faz
