RWD4ever
I have a VS and the handbrake light glows dimly at night. I have driven another VS and none of the warning lights do this. Both are same level.
The handbrake switch also connects to the speed alert to beep if you drive off with handbrake engaged. I suspect some currrent is leaking from the speed alert into the warning lamp.
Is this a common fault?
:hmmm:
:hmmm:
