Mapleston
- Jun 27, 2014
- 3
- 0
- 0
- Location
- Moss Vale NSW
- VZ 6.0 Litre Ute
Hello Everyone.
I really need the advice of the most knowledgable VZ commodore experts out there!
I bought a VZ commodore 6.0 litre with 150,000 on the clock.
An issue soon reared its head where I was getting all the dash lights, aircon, radio & clock turning off for a few seconds when driving. I also found that If I turned my high beams on during the time that this happened (when everything in the cabin was off) it immediately blew the bulbs!
I checked all the earth connections etc.
The next thing that happened was my alternator started to charge intermittently. I checked voltage to the battery and it was 11.80 odd volts, then sometimes I could hear the alternator working I checked the battery voltage and it was 14+ volts.
This has been happening intermittently with the alternator charging less and less.
So I pulled the alternator out and opened it up, the brushes are good, everything looked fine although I don't know how to check anything else on the alternator.
I realise that the regulator is computer controlled.
So am I on the right track? a new alternator costs a lot, I don't want to by a new one if its a PCM issue or is it an ABS module issue?
Please give me any little bit of advice you might have as I am interested to understand actually how this all works as well as wanting to fix the problem.
Thanks in advance.
Thanks in advance.
