VRSenator065
Now in stealth mode
- Jan 24, 2013
- 528
- 15
- 18
- Age
- 59
- Location
- Gawler SA
- VR Senator LSx454
I am wiring up a brake vacuum pump. I want to power it with 12V that comes on with the ignition via a relay. The pump will sit up under the drivers guard toward the front.
Can anybody suggest where I can easily pick up the 2 x 12V I need.
The battery is in the boot, comes up to the starter, then there is a main feed around to the fuse box in the bay. I guess I can pick up off this for the main 12V feed? But where can I pick up the ignition switched 12V for the relay?
