Sdperth
Hey guys,
I've read a few threads here to figure this out but I can't find a problem exactly like mine. Thanks everyone.
So when I hit unlock, the drivers door lock does not come all the way up. Then recently, when I hit unlock, the drivers door does not come up all the way, 4 seconds later all doors unlock and then I can hear a quiet ticking that I presume is the locks cycling. As you guys know, hitting unlock once should only be opening the drivers door. I've been having to open the rear door to get in. I've seen some people say try CRC or WD40. If that is my first cheap and easy option where is the best place to spray it. Should I take the trim off to do it? This recently cycling and all doors unlocking only started happening this morning, the door not fully unlocking has been going on a while. Thanks guys!
