Thanks heaps nut cracker that's the best help I have had in ages !
No problem.
How did you find out the wires were negatively triggered ?
If you look at the door key switch, the centre wire (Black/Blue), is connected to earth.
When the key is turned, this connection toggles between the other contacts either side.
This is the switch; the switch is connected to earth; so it's earth switched.
I have the haynes and Gregory manual is the diagrams in there ?
I found it in the Gregory's.
It's for the VZ sedan, but a VZ is a VZ any which way you slice it. The Ute just has less on it sometimes and
in your case, doors.
There is 6 wires coming from
My actuator which 2 are lock and unlock ? And how can I test them
Mate, I'm not entirely sure which ones lock and unlock.
The only way you could tell, is with a test light or a multimeter/voltmeter
and prob the wires as you lock/unlock the door.
I'd take the Light green/ yellow trace (unlock) and the Brown/White trace (lock) wires on the door switch as your reference to earth and with your meter/test light connected to them (one ta a time of course),
probe the other plug wires while locking/unlocking the door.
It wouldn't be hard. Just watch your test equipment as you perform the test and note which wire
has voltage when you turn the key either way.
Having said that. It would probably be easier to have a friend turn the lock, while you probe the plug.
