Possible Ignition Module Failure??
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
97 VT 5 Litre.
Been trying to sort out a problem with my engine.
To cut to the chase, I've found that when I connect the timing light to the leads on the left bank,
there's no light. The right side is ok.
It does idle ok and I'm thinking it's a weak spark on that side, that's why the timing light doesn't flash.
The engine does jerk a bit under load, as if there's a slight miss.
And does find it hard to come off idle unless I gently apply the throttle.
I'm tending to lean towards the ignition module, as the 5 litre only has one coil.
Your thoughts would be appreciated.
Immortality
Staff member
Sth Auck, NZ
I can't see how you would have a weak spark on one bank when the sparks all come from the same coil/module.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
I see what you mean...
So why would it only be leads 2 4 6 & 8
Iv'e swapped leads but it's still the same.
Immortality
Staff member
Sth Auck, NZ
How does the timing light connect to the ignition lead? Is it one of those induction type ones that connects over the lead? If so, these are polarity sensitive, if it's fitted incorrectly it won't read the signal.
Immortality
Staff member
Sth Auck, NZ
I'll take it the missing sparks are no longer missing?
No just to figure out why it's not very drivable.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Yup.....
Ok riddle me this.
Just out at the car.
With the timing light connected, The spark is very erratic under about 1200 rpm.
Above that, it's constant.
By the way, I tested on all leads.
This would probably explain why its having trouble coming off idle and that slight miss under load.
Immortality
Staff member
Sth Auck, NZ
What is the battery voltage like at idle?
Immortality
Staff member
Sth Auck, NZ
How old is the coil and ignition module?
