Results 1 to 5 of 5
Thread: VY Electric window switch into VL !!!!
    1JZ-GTE VL SL
    May 2005
    Default VY Electric window switch into VL !!!!
    Hi,
    Can anyone help me with the pinouts for the electric windows switch, I am trying to use a VY switch to run the electric windows in my VL.
    Rogue-VL
    1JZ-GTE VL SL
    May 2005
    *************bump*************
    Any body got and ideas on the best way to wire it up, obviously the VY switch isn't designed to handle the current draw of the motors as the VL switch does so relays need to be used.
    Any auto elect wizzards out there what would be the best relays and wiring up method.
    1JZ-GTE VL SL
    May 2005
    VY S2 Crewman
    Apr 2006
    According to the VY wiring diagram, a relay is only used for the main power feed. There must be high current switching transistors in the BCM to switch current to the window motors.
    As you won't be using a BCM in the VL, you'll need to use relays in your VL.
    Attached is a diagram of the VY switch pin outs..............
    Attached Thumbnails Attached Thumbnails VY Electric window switch into VL !!!!-vy-elec-windows-switch2.jpg
    1JZ-GTE VL SL
    May 2005
    thanks Cobra30 , that was exactly what i was after.
  1. Removing electric window switch unit VX ?
    By VXS-747 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-10-2007, 03:22 PM
  2. Electric window switch wiring
    By Rogue-VL in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-07-2006, 07:59 AM
  3. Electric window Switch wiring
    Last Post: 01-07-2005, 10:50 PM
  4. Electric mirror switch
    By cuckoo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2005, 11:23 AM
  5. Electric Window switch
    By blue alliance in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-09-2004, 09:25 PM
