Just thought id share that I put the factory driving lights onto my VTII Berlina with a factory Calais Bumper. A fairly easy job to do once you have the dash fascia removed to allow access to the headlight switch and the fog light switch placement. I removed the wiring from a wrecked VX SS and simply placed the wiring into my vehicle. The wiring simply joins to the headlight switch for earth and power then another wire runs out to the relay box to operate the relay (hardest job to do :b: ) which I placed into the original position inside the relay compartment. Another wire from the foglight switch then goes across the dash to the illumination circuit and its all done allowing the foglights to come on when the parkers are on as factory fitment. The switch even dims with the rheostat. Neat
