Results 1 to 3 of 3
Thread: removing plastic covers
    bundy Guest
    Default removing plastic covers
    hi,
    i've got a 94 vr and am running the leads from my amp to battery and cd player, im running them under the plastic things where the carpet is tucked under near the doors. does anyone know how to get the plasic things off?? would b a big help
    talgenn Guest
    You will need to remove the rubber strip that runs along the length of the plastic cover. Then squeeze the cover so that you close up the gap where the rubber strip was. Should come off easy enough. Happy wiring.
    bundy Guest
    thanx for ur help
  1. Help removing plastic door strips
    By dean_jely in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-11-2007, 08:34 AM
  2. Removing the clear Odometer plastic screening
    By VZCrispey in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-04-2007, 05:17 PM
  3. Help with removing plastic sides of vn commodore
    By Vn_666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2006, 08:56 PM
  4. Removing cig lighter from plastic console
    By Wire in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2006, 11:58 AM
  5. Plastic Engine Covers on Vs
    By BobT in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-04-2005, 09:24 PM
