Results 1 to 5 of 5
Thread: gear selector light not working
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    Default gear selector light not working
    on my 1990 vn wagon my gear selector light doesnt work. i have checked the bulb and it looks fine. the ciggi lighter light works fine so wat would it be.
    thanks
    Adam
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    the globe could be blown even tho it doesnt look like it. try testing the globe socket with a multimeter or chuck another globe in it. i recienty changed mine and it was about a buck. have you checked fuses?
    Jan 2006
    stanthorpe, qld
    Quote Originally Posted by azzfox
    no i havent checked fuses but after i posted that up i thought about swapping the ciggi lighter globe and see if it works in it. do u no if there the same globe
    Adam
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    cigi lighter has a screw-in globe. but the globe in the steering column is the same that shines on your keys. if you want to use that there are a few screws on the bottom where the ignition barrel is. take tem out ant the bottom cover will come off and you can access the globe (its not hard). i can take sum pics just in case u dont feel comfortable doin it.
    Jan 2006
    stanthorpe, qld
    Cheers i will do it tomorrow
    Adam
  1. Heater Selector thingy isn't working...How do I fix it?
    By 1vngal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2006, 11:08 PM
  2. Gear Selector GLOBE
    By tr3nt in forum Electrical Wiring / Questions
    Last Post: 15-10-2006, 04:04 PM
  3. Gear selector light out on column shift
    By MarzVP in forum Electrical Wiring / Questions
    Last Post: 26-06-2006, 11:54 AM
  4. Gear selector Pic Vn-Vs
    By Snotty in forum General
    Last Post: 22-05-2006, 04:22 PM
  5. Blue Gear Selector
    By AirStrike in forum General
    Last Post: 23-11-2004, 06:41 PM
