Results 1 to 4 of 4
Thread: indicators to go off with central locking
    ben k's Avatar
    ben k is offline ben
    VP Calais S2
    Aug 2005
    radelaide...bay area
    Default indicators to go off with central locking
    ok guys
    wierd question but yer...want to do this
    is it possible to hook the indicators up with my central locking so when i lock or unlock the car the inidcators flash in the same way as the more recent commodores
    i have a vp executive and yer central locking with the button thing.
    cheers
    ben k
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Hook up the 12V wire on your central locking to the hazard lights wire under the dash.
    When the doors lock or unlock, the lights will blink.
    ben k's Avatar
    VP Calais S2
    Aug 2005
    Atreidae is offline (Was an) Installer
    VN Calais
    Oct 2005
    Err you may want to put a few diodes in there...if you tie the +12 trigger to the door locking to the indicators you are effectivly tieing the two indicators together.. and both with flash when you attempt to indicate.. the indicators will also attempt to power up the locking motor everytime the indicators flash.. this could also damage the output transistors/relays on the central locking box
    it could get even worse if you try to hook lock and unlock upto the indicators without any form of protection as you are effectivly shorting the earth and +12 lines of the motor together via the indicators (depending on motor setup.. the vp eludes me atm)
    as simple as the idea is.. you just need some protection.
    get some diodes that can handle the amperage.. grab the +12 signal from the lock on the central locking. use the two diodes on the end of the signal in parralel and goto the indicators from there
    drop me an email if u get stuck.. as i dont drop in here often
    atreidae at chibiko.net
  1. Central Locking
    By caminsa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2007, 02:49 PM
  2. central locking in vn
    By Zuicider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2007, 07:47 PM
  3. VP central locking
    By Dazzamcgee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-12-2006, 07:57 PM
  4. Central Locking
    By fatboy2869 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-12-2006, 01:28 AM
  5. Indicators Don't Flash When Using Remote Locking
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2005, 09:23 PM
