Results 1 to 3 of 3
Thread: Earthing earthlings.
    vnberlwagon Guest
    Default Earthing earthlings.
    I have no idea about power requirements, earthing of different things in the engine bay. What is the best way to make sure all earth wires are correctly grounded or require a clean up?
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    If you're not having problems then you probably don't need to worry about it. If you wanted, you could unbolt the engine block earth cable, file the terminal a little bit and put it back on. Do the same to the chassis cable if you have one. Make sure the battery terminals are half decent and replace any wiring that is badly frayed or taped up with dodgy electrical tape. Check inline nylon connectors for terminal rust, file them up if nessesary. And avoid using electrical tape unless it's really nessesary. I hate the crap and it is done by dodgy backyard mechaincs plus it isn't tidy. Use heatshrink tubing instead.
    VYII SS UTE
    Feb 2006
    nothing like tape gone soft with solvents/oil and is all takky or on the other hand all dried up and falling apart and keeps ripping when you want to pull it off,
    Cheers for heatshrink!!
  1. Earthing Issue Maybe?
    By Sabbath' in forum Electrical Wiring / Questions
    Last Post: 07-07-2006, 06:32 PM
  2. moving earthing wire ??
    By VSAccCom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2005, 09:32 PM
  3. 1996 VS Belina Earthing Points
    By Kevin in forum Electrical Wiring / Questions
    Last Post: 29-01-2005, 11:43 PM
  4. Earthing a head unit
    By HsvMan in forum Car Audio
    Last Post: 07-10-2004, 06:58 PM
